Usb
Maromi
Usb
Usb mode does not switch!
gt
profile.country.PH.title
MarlonUk1
hello @Maromi
are you talking about attaching a usb flash drive into the device? or using the device as mass storage? try to install Xperia companion on your pc to make sure all drives are installed , make sure to use a usb cable that allows data transfer..
