Hello
I have a problem I didn’t find any solution on the internet. When I click a web link in the email app, a small windows opens with the browser content. Is there a possibility to disable this function and instead open the standard browser? Thanks for your help.
Kind regards
Beat
For me it worked to install the chromer browser and chose it as default. Deactivate other browsers or setting guide if relevant.
Hi I have the same problem since owning my new xa1, try'd many settings in the phone but makes no difference, really is a pain, will watch this forum for answers
@Dendrobates wrote:Hello
Kind regards
Beat
Hi I've opened settings, apps, email, open by default, supported links is stating dont open but is greyed out and I can't find any way of changing this, thinking this could be the problem lf I could change this setting
Same issue. Screenshots attached. the small window that opens up is somehow the setup wizard and I have no idea how to disable it and get it to use Chrome. Even links opened within the Facebook messenger - give you the option not to open in chrome as it should but in the setup wizard like it thinks the setup wizard is the standard browser!!
I have found the solution. You want to disable Setup Wizard.
Go to Settings>Apps click on the three dots (top right) and click 'show system'. Scroll down the list to 'Setup Wizard' and disable it.
It worked for me, Thanks @XenoMorph
For Android 8.0 Try:
Settings>App¬ifications>Apps info>click 'show sytem' from three dots menu on top right corner>find&click 'Setup Wizard' apps>click disable
It worked for my Sony XZ1 !!
That's it! Finally. Thanks @XenoMorph and @DreamMaster.
