Hi, any idea whats the solution.
I have a Samsung Wireless charger, and when I connect to the network it seems indicate as it should, but when I put my XZ3 on it nothing happens..no indication on the mobile or the Samsung Wireless charger.
Any idea what to do???
Thanks in advance.
Thanks, as fare I understand Xperia XZ3 have QI..is it maybe some turn on/turn off I have to do on the mobile??
none that I'm aware of, but if your phone has a protective case that might be the issue
https://support.sonymobile.com/global-en/xperiaxz3/userguide/charging-your-device/#gref
Yes it's something you should activate from settings.
Go to settings - - sound--advanced - - - then enable the charging sounds
Good luck with your wireless charger, I love mine 😊😊
