XZ Premium tinted screen?
profile.country.PT.title
NunoSEN2
Hero
Hello;
I just bought a Xperia XZ Premium (G8142) and comparing the screen with my Xperia Z5 I notested that the whites are somehow warmer (to the yellow) than the Xperia Z5.
Increasing the blue in the white balance improve it but not 100%, I am wandering if this is normal on the Xperia XZ Premium or if there is some problem with my display because I read in some early reviews the opposite (that the coulors tend to be cold with more blue).
I would like to know if someone else is having the same issue. Can my display be defective?
profile.country.PL.title
najodleglejszy
@NunoSEN2 your best bet would be to find another XZP (in a store, perhaps), and compare the displays. from what I recall l, my XZP's display is slightly warmer than X's (which was colder than Z3 compact's).
5 REPLIES 5
najodleglejszy
Andyben
check what "Colour Gamut & Contrast" display setting you have, Standard or Super Vivid give bluer whites, Professional Mode more yellowy
NunoSEN2
Hero
Hello;
Thank you for your comment, but that happens in all display settings and I usually use the standard (I tried all the settings available and what corrects it to a better degree is really increasing the blue in white balance but I can´t equal it to the Z5 whites.).
profile.country.FR.title
ClarkLong
Yes it's "normal" all XZP screen are more yellowish than Z5 series. It started with XZ
Ghio
Hi!
I have this yellowish hue on my XZ premium compared to my Z5 premium. I have also adjusted to super vivid and standard mode and still no change still yellowish. This same thing happens again since the Xperia Z1 which has also yellowish hue.
