Alarm - Sound Picker
ppzmanu
Dear all,
I have a small problem.. don't understand how it can happen.  When i try to edit the alarm sound of my Z1 compact, there is no more the sound picker, just only access to ringtones... so I can't set a song for instance.
This was possible "before" as I have some alarms with songs.
I haven't read all the forum and may be this bug is already fixed.
Eric
profile.country.RO.title
_alexdon_
Then look for alarms and clear defaults.If this does not work either,when you are in settings-apps-all,tap the 3 dots and reset app preferences.
alexdon
_alexdon_
Go to settings-apps-all-sound picker,clear defaults.
alexdon
ppzmanu
Thanks for the quick answer but i had nothing to delete (cache or default).
_alexdon_
alexdon
