Android 5.1.1 update - problems
Menaka
I upgraded my Z3 dual into android 5.1.1 and now I experience following problems.
1. Fast battry drain
2. Headset mic doesnot work when taking a call. I have to unplug and replug it. For incoming calls its ok.
3. Mic does not work at sometimes when taking a call. No problem for incoming calls.
4. Music player does not remember settings and I have to reset them when ever I use headset.
I prefered sony mainly beacuse your good quality and outstanding products. I hope you will consider those things and give me some solution.
profile.country.US.title
Qatrium
All these problems have been discussed on the forums multiple times. Use the search feature and you'll find them.
Qatrium
profile.country.RO.title
_alexdon_
Thread locked.
alexdon
