App is stored on SD card error message
Eyevy
once moved to my SD card i try to open the app and the message comes up ( when i retart my phone ) . the apps dont work
when I try to open the application I get a message saying
(Apps name) unable to open
I've tried to restart my phone.but it seems that the apps have been deleted for some strange reason. I've serched through my sd card and there is no sign of the apps anywhere.
App to SD card movement works showing it has moved to SD storage i have tried moving the apps through app2SD app , This only works when i have moved one or so apps to my phone using the the settings and moving it on android its self
12 REPLIES 12
rdvecchia1
I have the same problem. And I'm pretty sure my sd card is not corrupted, because I can access all my files in it. Every now and then it starts to work, but when I restart my phone the problem is there.
AgustinRosas
I'm now having the same issue. I have installed some apps on my external SD card, but whenever I restart my phone, then I can no longer access to them.
I have tried restarting the phone and cleaning the SD card over and over again, but it doesn't seem to work at all.
I can access to photos that are stored on my SD card, the problem is only related to the apps.
Anybody has a clue about this?
Thanks!
Tags (3)
Comeon
I can access everything on SD card but the apps, they are simply not there.
All my apps were working fine last night but today they are not. I have not changed anything.
Sony I need help with this.
