Hello
I've got Z5 Compact with Customized DE fw and I've got a weird problem.
The other day I was using my phone extensively and managed to get 7 hours of SoT. Which is great.
Then, following days, I've been getting 3.5 hours of SoT, but I wasn't using it much and it would need charging every ~50 hours(so 2 days). Which again is brilliant.
But last two days, it lasts about 24 hours with just 2 hours of SoT.
Why is that? I've checked battery consumption and Android system has kept it awake for 2.5 hours, but after restart Android system is no longer in battery consumption list.
Some Marshmallow bug maybe?
Charge the phone 100% > use it as you normally would > then once the battery level reach 10%
settings > battery > tap on the battery icon > take a screenshot of the graph > tap on the top 5 items on that list > take a screenshot > post them all here .
Don't forget to check your past posts
Battery Historian isn't working so I can't check if fast dormancy is still a problem.
Here are SS's
