Camera Album Shortcut Option
AshJng
I am wasn't having any issues until my camera couldn't launch.
I did a normal power off and on the phone and relaunch the camera app.
However, the camera shortcut to the album to view photos has been changed to google photos.
It was previously the sony album.
How do I change it back to the sony album?
Thanks!
AshJng
discretion1
I think he means the shortcut in the Camera app to view recently taken photos. May be you set Google photos as the default app to view photos in one of the confirmation windows. Does opening photos from file manager too is through Google photos automatically? If so, try clearing defaults at Settings--Apps-All--choose Google photos--Clear defaults. Reboot if it doesn't correct the problem.
4 REPLIES 4
Er_Kannan
Do you mean the shortcut on the home screen? Google photos and Sony Album are two different applications. You can search for Album to find the Album application.
discretion1
Er_Kannan
I too feel discretion must be right.
AshJng
Hey thanks discretion!
Your solution worked! Grinning_Face
