Camera button missing stage
Atacama1
This morning i woke up and found that the camera on my Z3 was starting without a reason.
Looking into that i found out that the camera button on the side was easy to press, almost with stroking over the button. There is also no travel when pusing the button anymore (like the power or volume buttons has).
In the camera app, that starts when stroking the camera button, i cannot use the same button to actualy make the picture.
It seems half of the travel has gone. Is this a known problem, has someone tips how to solve it?
CameronT
Champion
Hi @Atacama,
Welcome to the community.
This is the physical camera button, right?
I'd recommend you contact your local support team as you may have to arrange a repair on your handset.
CameronT
Champion
Hi @Atacama,
Atacama1
Yes, i mean the physical button. I was afraid for that answer, thank you.
