It seems like an obvious question, but I want to avoid making a fatal mistake!
Please note: the only reason I wish to do this is for convenience (1 cable permanently attached to my pc/ 1 cable permanently attached to charger).
I can see the Sony & Nokia micro USB cables are "identical".
I have plugged in my Sony charger plug to the electricity with the Nokia micro USB attached.
When I then connect it to my Sony z1 the device appears with a message “Go Connect”…
I have not continued until I get some advice please.
I really appreciate help – it will simplify my life!
Phone: Sony Z1 Compact
Android 4.4.4
Sony Charger plug: EP880
Sony USB/ charger cable: EC801 [micro USB data cable]
Nokia cable: CA179 [micro USB data cable]
Solved! Go to Solution.
A cable is a cable - Some cheap and some not - The use of a standard fit is to stop manufactures claiming part of the market for themselves however there are some manufactures that are exempt - So yes the cable will be fine - If using it froma mains plug then the output should not exceed 5v and 1.5a or 1500ma
Thank you Thommo. Perfect. (I know it seemed logical but I wanted to check there wasn't a catch).
