Hi
I can't delete somr contacts on my sony xperia z3 compact. Specifically those associated with whatsapp, skype, etc.
How can I delete them?
Danny
THANK YOU...........THANK YOU...........THANK YOU......
This has been a pain for some time..... you Sir are a magician...
That worked - thanks!!
I want to delete..but it will just state cannot delete to contact
just go to contact, on top right side three dots there just click it there will be many options goto filter there is display contact option there are many sub menu local contact,google,whatsapp. just select whatsapp uncheck all contacts option and go back to contact list goto number you want to delete tap on pencil like edit option there will be whatsapp icon click on it there will be unlink option tap it and save it and then delete option will work in contact option. (three dot option on top right side)
