yesterday night after updating android M i'm not able to select 20.7mp in superior auto mode only options are 8Mp(16:9) and 8Mp(4:3). i'm stuck with 8Mp camera in 20.7mp phone. 20.7 mp works in manual mode but i can not do any settings. Please solve this issue android L is much better and do not you people do testing before releasing??
Topic edited by Rickard
thanks but it was working yesterday i was able change settings to 20.7mp
That's odd, as Superior Auto use pixel binning, and reduces the pictures to 8MP, @alexdon could you test this on your Z2?
@uliwooly@vikram_shadow I will check but the Z2 didn't get MM yet. Are you sure it worked before? I thought only new devices have more than 8MP on superior auto.
20.7mp is not available in superior auto mode in Z2. You need to switch to manual to use this resolution. It was the same on Android 5.1 so it's not something that has been removed in the Android 6.0 update.
