Circle stays on screen
Silentml
hi ,
Pls refer to the screenshot attached . Kindly advised how to remove the white circle which appear on the screen.
Please advise how to get rid of the white circle. It stays on the screen and very annoyingPlease advise how to get rid of the white circle. It stays on the screen and very annoying
4 REPLIES 4
profile.country.RO.title
_alexdon_
@Silentml I think it is related to developer options, which you should find under settings - about phone. There is an option called show touches, try to disable it.
alexdon
Silentml
Hi, I can't find the show touch option under setting -> about phone. Pls refer to the screenshot attached. Slightly_frowning_FaceScreenshot_2018-12-08-15-08-43.jpg
_alexdon_
@Silentml first, enable developer options by tapping about 7-8 times on build number. Then, look for the option I told you above.
alexdon
Silentml
Hi , I had done that before, but still don't have that option of show touch appearing .
