Crash dump
profile.country.fr_FR.title
luvaholic
Crash dump
Hi there
I have recently acquired an Xperia Z Ultra and it seems to be sending SMS to international numbers along with using around 5mb of data randomly.
Upon further inspection I noticed that the times it uses data/ sends these SMS relates to the times at which the phone has crashed and created a CrashDump file.
It seems the phone is sending the CrashDump files to an overseas number and using the data also.
I also reinstall a clean firmware and check my apps...
I was wondering if there is there any way to stop this communication?
Anyone got any information on the matter?
Thanks a lot for any help in advance
Rickard
Master
Could you please send me a PM with your IMEI (Settings -> About phone -> Status) and which software version you have (Settings -> About phone).
Rickard
Master
Mitch07
Hey there,
I am having a similar problem am i able to send you the same details to fix this?
Mitch
