Fast Charging not working
Ivanaldo22
Hi, my Xperia Z2takes almost 1.5 hours to charge up to 60% i am using the same charger came in the box with my Z2 please help how i can fast charge my phone
profile.country.RO.title
_alexdon_
Your device doesn't support it most probably,unless you have the japanese variant.
alexdon
10 REPLIES 10
_alexdon_
It should take over 2 hours to fully charge your device. But slow charging might be related to other things,like using the device while it is charging.
alexdon
Ivanaldo22
The written GSMArena quick charge 2.0 60% 30 min
Ivanaldo22
Where to bought it?? Im in Indonesia
_alexdon_
alexdon
Ivanaldo22
Thanks :d
987789
My z2 also does not charge fast..It also take 3 hours to full charge
Uliwooly
@987789
That's normal, the Z2 doesn't support this.
Uliwooly
http://talk.sonymobile.com/t5/Software-Updates/Quick-Charge-2-0/m-p/1004965#M24077
To be able to utilise the Qualcomm Quick Charge 2.0 technology, phone as well as the charger need to support Quick Charge 2.0.
Currently, there are no original Sony chargers that support the Quick Charge 2.0 technology. This means that, at present, you cannot charge Xperia devices using original Sony chargers utilising Quick Charge 2.0.
However, some Xperia devices and magnetic charging docks are prepared for and support the Quick Charge 2.0 technology. Again, as there is currently no original Sony charger that supports Quick charge 2.0, these devices cannot utilise Quick Charge 2.0 using an original Sony charger.
The following Xperia devices support Quick Charge 2.0:
Xperia Z3 Compact
Xperia Z3 Tablet Compact
Xperia Z2 Tablet
Xperia Z3 (only Japanese variants SO-01G, SOL26 and 401SO)
Xperia Z2 (only Japanese variant SO-03F)
The following magnetic charging dock supports Quick Charge 2.0:
Magnetic Charging Dock DK48 (for Xperia Z3 [Japan] and Xperia Z3 Compact)
More information about Quick Charge 2.0 at www.qualcomm.com/news/snapdragon/2014/06/04/quick-charge-20-has-arrived
