Film inside the phone above the nano sim slot
Debra47
Why is there a line of film inside the phone above the nano sim slot and how do you get it back in please?
Uliwooly
6 REPLIES 6
Debra47
Also my phone keeps heating up and I turn it off, is this normal please?
Uliwooly
@Debra47
Are you referring to this?
http://support.sonymobile.com/global-en/xperiaz5/userguide/IMEI-number/
just slide it back in
Uliwooly
@Debra47
As for the phone heating up, that's normal, the longer you use it the hotter it'll get also, if you record on 4K it will heat up quite fast.
Debra47
I basically turn the phone on and it's very hot. So then I turn it off. Ive just bought it. So I am a bit concerned. Thanks.
I think the "tray" for the imei is broken. What should it look like please?
Uliwooly
@Debra47
Repair the phone with PCC
software repair
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
azzido
Enthusiast
The phone will be hot for w while as it is new and it is collecting all media information, saving down all the settings, syncing out all your accounts etc. especially if you have sd card inserted. This is normal for all new phones so do not worry that much, it will be better after some time Winking_Face
