I downloaded the xperia mirror small app, but now every time I capture a photo with the front camera, when saved the image is fliped. I tryed to uninstall the program, but the problem persist. I cannot find a solution for it and it is so annoying as the "selfie" photo when flipped becames tottally different.
Is there any how to solve this issue?
Solved! Go to Solution.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
The front facing camera captures the portrait correct but the view finder in the camera application works as a mirror. This is how the front facing capturing mode is designed to work and it's not possible to change this via any settings in the camera application. It's possible that there are third party camera applications available on Google Play store that works differently, if you prefer the view finder not to mirror your portraits.
If you want to flip the image, you can use Pixlr Express.
It was installed standard on my phone, or you can download it from Google Play.
https://play.google.com/store/apps/details?id=com.pixlr.express&hl=en
