FW 32.1.A.1.1​​81 SE fix bugs
roerisigold
Guys !!!!!!!!!, Great News !!!! , I installed this firm and it would seem much more stable, for now I have solved the problems of the continuous disconnections with FM radio and bluetooth and continuously monitoring, the only flaw is the branding of the firm 3 SE
SebastianD
Do you have auto brightness gamma issues a few seconds after turning on the screen under the sun? (More easy to check this with a black wallpaper).
4 REPLIES 4
SebastianD
Bhonder
@roerisigold
Which radio and bluetooth version number is beared by this update?
kragoth
Its new firmware via OTA
roerisigold
no ftf brand 3 Sweden
