Getting hot while recording hd video
Naveen9172
Dear Team,
even after upgraded to android N, still facing the same issue while running 4k or hd video.
The device is getting hot, and automatically exit camera.
Please support to fix the issue.
Regards
Naveen
profile.country.PH.title
MarlonUk1
I don't know but this happens to other devices too. the max I have recorded with 4k and 1080p @60fps
is just arounf 10 minutes
here are tips:
1,) move the storage to internal
2.) it helps if the device is fresh from boot up
3.) make sure there isn't much background process on
4.) try to record while you are on safe mode
