Help sony xperia z3
The phone had 50% charge. used the camera suddenly the phone turned off .. I tried to turn it on. the red indicator light turned on, I put it on charging and the red indicator lights constantly on the charging and on the black screen the red battery. not included (((
Помогите sony xperia z3
На телефоне было 50% зарядки. пользовалась камерой вдруг телефон выключился.. Я пыталась его включить . загорелся красный индикатор, я поставила его на зарядку и на зарядке постоянно загорается красный индикатор и на черном экране Красная батарея. не включается(((
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
I'm sorry to hear that but you will have to get it inspected by your Local support as that's a hardware issue.
