How do I delete my SIM contacts?
UZIEREK
I have tried a range of applications from google play and they do not seem to work. I changed to original device where I transferred those contacts to SIM and tried with a range of apps but it did not work either. How do I remove all of my contacts stored on SIM card?
profile.country.RO.title
_alexdon_
@UZIEREK What I have used before and worked correctly is:
https://play.google.com/store/apps/details?id=com.needom.simcontacts&hl=en
alexdon
UZIEREK
Tried this app it did not help.
exsanguinator
My Z3 is on kitkat.
Seems like you cant delete sim contacts on kitkat or its just a Sony Z3 limitation.
You can import and export to sim.
Not sure on lollipop or marshmallow.
I have a Motorola on jellybean and it can manage sim contacts fully.
Maybe insert your sim into an older fone if u really need to delete your sim contacts.
Or buy a 99c sim card reader of ebay.
