how to change it back?
MaruChi
When there's choice box "complete action using", I accidentally choose "always," so now I can't choose again from which application I want to open the file...
How can I change it back to having that option again? Please someone help me...
Tags (1)
profile.country.RO.title
_alexdon_
I would advise you to reset app preferences,this can be done for all apps.
alexdon
8 REPLIES 8
_alexdon_
Settings-apps-all,look for your app and clear defaults.
alexdon
MaruChi
Umm...actually I didn't know what app I should choose to clear default...
You see, I was trying to change my phone ringtone & notification sound, usually I got 3 options from where I want to pick the sound, but then I accidentally click "always" instead of "just once"..
so in all apps,which one should I choose?
There are just sound enhancement & sound picker, but both of them are "no defaults set"
Thanks b4
_alexdon_
Sound picker.
alexdon
MaruChi
Like I said before, in sound picker, the launch by default box is "no defaults set"
MaruChi
So the clear default box is un-clickable
_alexdon_
alexdon
MaruChi
Thank you so much for your advice.. I had reset app preferences and when I try to change my ringtone, the complete action using box popped up.. Thank you so much.. You've been really helpful..
_alexdon_
Great.
alexdon
