how to Change lock Screen watch fonts??
auron
After the latest Update ı couldn't Change the bold font Of the watch's hour..
srv1
I don't know then Thinking_Face
Have you ticked "allow widgets on lock screen"? I've got four clocks i.e. digital clock dark and light, then Sony clock dark and light  (+ other clocks but these are from HD Widget app).
13 REPLIES 13
Thommo
Genius
Z2 or a Smartwatch?
auron
It's z2 phone's watch on
the ockscreen
Thommo
Genius
I don't think this can be changed - As far as I'm aware there is only one to choose from which is the default clock
auron
I can't remove it either.. Any WAY to remove that clock?
srv1
You can put something else to lock screen instead of clock (there are also different clocks to chose for).
auron
How can ı do that??
auron
I couldn't Find the others
srv1
Enable screen lock  in Settings > Security section and then choose other clocks or sth else...
auron
There isn't such a section there as other clocks.. There you can only choose the way Of locking Screen..
