how to delete words from keyboard suggestions
Neet
Whenever I open any website it saves its name and suggests in keyboard.... how to delete it?
Tags (3)
discretion1
What keyboard do you use? If it is the stock Xperia keyboard, Go to Settings--Language & input--Xperia keyboard--Text input settings--My words--long press on any word, the word will be marked and check boxes will appear for other words too, and there will be a delete option at the bottom.
If you use some other keyboard from the Play store, try this location: Settings--Language & input--Personal dictionary.
discretion1
Βα
How can I remove from my ancient XperiaL suggestions plus vibrations on SMS writing. It is getting extremely annoying. Please HELP!!!!!!!!!!!  On the merge to shrink
