IMEI - how to find
Jimmybobkins2
IMEI - how to find
Hi
Where can I find the physical imei number on the Sony z3 plus?
Uliwooly
@Jimmybobkins2
Open the SIM cover and look for a plastic strip or check the box.
Emil
Enthusiast
Hi @Jimmybobkins2,
Welcome to the community! Slightly_smiling_Face
As @uliwooly said, you can check your IMEI number on the on the label strip located under the hatch for the SIM and SD card. You can see exactly where to look in the picture bellow.
ILL-SONY-14IY-KRC-low
Let us know if this helps!
Whippett
By this do you mean simply just the IMEI on the phone software or what because if you mean the software all you need to do is click on the dialler and type *#06# which will key it in automatically to work for you
