Increasing Volume option doesn't work
Todorov
As the title says - it starts ringing at the level i've set it.
I'm seting ringtone volume at maximum because of the ridiculously low notifications sound.
Todorov
A factory reset fixed it.
14 REPLIES 14
Uliwooly
is there anything blocking the loud speaker?
Todorov
Nope.
Uliwooly
Is Xloud on?
Todorov
@uliwooly wrote:
Is Xloud on?
I don't have such option in Sound
Uliwooly
check settings > sound > sound effects > sound enhancements > settings
Todorov
Nope.
I have only Equalizer, Surround sound (VPT) and S-Force.
Tried ém all and nothing is different
Uliwooly
That's quite odd, you might want to stop by a Sony repair center
http://www.sonymobile.com/global-en/support/contact-us/
Uliwooly
Have your phone been in contact with water at all? if it has then you have to wait for the speaker to dry out entirely
BaZhAnG
http://talk.sonymobile.com/t5/Xperia-Z3-Z3-Dual/notification-volume/m-p/844129#U844129
U might want to look over here, not a single soul of support is done over there, when we want is our notification sounds and tones to be loud that's all, meaning sms, whatsapp, Facebook, which ever app tones or ringtones to be loud, when people calls us, our Z3 ringtones are loud, but notification TONES are soft.
Does the support team ever give us a answer?
