Solved! Go to Solution.
Info-eye is a function in the camera. Start the camera, tap the button at the lower right and select "Info-eye".
also on the off chance that you may have disabled this app to get it to update as I had to do - remember that disabled apps are right at the bottom of the All/apps list in settings
it only needs update go to sittings-about phone-software update install the update and you will be able to see it
It is not possible to install Info-eye 1.2.04 I have tried to install it more then 10 times it is downloading and in the end i am getting message that it does not installed successfully
