Dear Sony
My phones internal storage is full (11/11.5GB used). I have transferred everything I can to my SD Card which is half full but there is no more to transfer. I have now attached my phone to my computer to look to delete further files. When I open the phone it says the Internal Storage is full, but when I go into the actual internal storage, the largest folder is only around 38MG. I don't understand where all the data is that is filling up the phone given I can't access any of it.
I hope this makes sense. Thank you for your help
Kind Regards
Jack
Hi @Jack_C,
Here's some tips for managing your memory.
Uninstalling unwanted applications to increase the amount of free internal memory
If the Uninstall option isn't available, the application can't be deleted. Most preinstalled applications can't be deleted as they are integrated in the operating system of your device. All applications that you have downloaded and installed from Google Play can be deleted.
To uninstall an application
Clearing the cache and the data of applications on a regular basis
Applications occupy an increasing amount of storage when they are in use. The occupied storage can be distinguished into:
To delete the cache or the data of an application
Backing up data to different memory types
Generally, you should not save photos, videos and other personal content solely in the internal memory of your device. If something should happen with the hardware, or if the device is lost or stolen, the data stored in the device internal memory is gone forever.
You do not need to back up or make a copy of applications that you downloaded from Google Play (Play Store). They can normally be downloaded again if you have set up a Google account in your device. You can find the apps which you have purchased under My apps in Google Play, so you will not need to either pay, or search, for them again.
I have the same problem. Using Treesize shows only 2.2Gb actually used, whereas the folder view on windows reports just 431Mb free out of 11.5Gb!!
Your reply so far doesn't answer the questin of where is all the 'hidden' data.
Internal storage full also memory full you can help me sir
