Is using 360 security a good choice?
prodigy
Hi everyone. I've bought my Z2 phone with AVG security, but the app doesn't work at all. I don't know why? It stops by itself after a very short period of time. So I uninstalled it. I installed 360 security instead of it. I just want to know if this choice is good or bad? Is there anyone who is using this app, tell me about his/her opinion. Thanks for everyone.
Thommo
Genius
360 comes 15th in the security and useability tests Avast comes 3rd behind AVL and Ahn Lab but scores the same 99.7 overall however Avast comes with 1 or 2 more features than those other 2 mentioned, Kapersky has dropped from 1st to 12th
And as said one of the top AV's in a none English app AhnLab
4 REPLIES 4
Thommo
Genius
The best free security app is Avast and the best of the best but is a paid for app is Kapersky - Avast free comes in 3rd place with some Chinese app 2nd but is only available in that language - The paid for version of Avast is the same as the free version but comes with unlocked features which unless you are rooted means nothing special
prodigy
Thank you Thommo. Do you mean that 360 is a bad choice/ Or is it Ok?
If not I'll work with Avast.
Thommo
Genius
prodigy
Thank you Thommo.
I'll begin to use Avast.
Thanks.
