i updated today to lollipop. But now in my lock screen security settings i can't select "none" or "swipe". I have already tried disabling the administrators. What should i do?
Solved! Go to Solution.
I am not sure but you can try clearing the credentials in security.
This option it's not available on Lollipop
Make sure to contact Sony regarding this
Hi shivam1
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you set up any corporate type of email on your phone that would require you to have a lock so no one can access personal/business information?
I found the solution.
You can clear the credentials (in Security) and then you can switch the screen lock.
