my xperia zr sys was deleted
hewr
hi i have problem with my xperia i was deleted my xperia system and i dont know how to install an system for my xperia???
5 REPLIES 5
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
alexdon
Uliwooly
Have you roted your phone?
hewr
no I didnt roted my phone
hewr
alexdon it not worked
_alexdon_
Let a sony service handle the device:
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
