No FM radio?
Josem1974
No FM radio?
Desde la última actualización, he conectado la radio Fm, y no se escucha, se acopla con el micrófono, he probado con auriculares y cuando activo la radio  me escucho yo mismo!!
Since the last update, I have connected the FM radio, and it is not heard, it is coupled with the microphone, I have tried with headphones and when I activate the radio I listen to myself !!
GT
Tags (2)
ptbankie
I had this fault after an upgrade. It is because Google Now is trying to use the microphone. Go to Google Settings and change "Ok, Google" activation in any screen. This should fix your problem.
JJN1
Hola, desde hace como 2 meses ya no se escucha la App de radio FM que viene de serie en el Xperia Z2. Aparece la carátula cuando conecto los auriculares pero no se escucha. La música en otras aplicaciones si se escucha con los auriculares. ¿Qué puedo hacer? GRACIAS.
Hello, since about 2 months ago you can not hear the FM Radio App that comes standard on the Xperia Z2. The cover appears when I connect the headphones but can not hear it. Music in other applications if you listen with headphones. What I can do? THANK YOU.
GT
