Hello.
It is really weird, but Xperia Z5 compact can not record STEREO sound in video.
This is 2015 and you think that users will accept mono audio even in 4k video.
Are you serious?
Even my nokia N8 can record nice stereo.
P.S. Actually N8 camera in most cases takes better shots than Z5, despite slow matrix and really awful software
Hi there. Xperia Z5 Compact can record stereo audio in the video player. You can check the service menu to see if there are any issues with the 2nd microphone. *#*#7378423#*#* > Service test
Greetings.
There is a stereo sound. I'm sorry. BUT I've found some awkward bug/or feature.
If I'm recording video with wired headset it will use microphone from headset to record audio. Thus there will be mono audio stream.
I do not think that phone should use microphones from wired or bluetooth headset by default while recording video.
At least I MUST have some notification (icon for example) that will show me that external microphone is used.
And also it will be better to have such option as disabling external mic usage.
As I can understand support for external mic is only useful if I will connect sony stereo microphone to my phone. And this is pretty rare case.
Regards.
rumatoest it is so normal that device will use exterior microphone if you plug same in it...but option to choose defoult mic could be helpful I agree.
I'm not sure if you have a Sony digital noise cancelling headset, but if you do. Try to use that while you're recording video.
That would help for stereo sound and also would provide binaural effect on your video. Thats because the headset have both left & right microphone for noise cancelling and the mic will also be activate for video recording to capture sound for left & right input.
uliwooly, have also comment on your other post about this.
Bandolero wrote:I'm not sure if you have a Sony digital noise cancelling headset, but if you do. Try to use that while you're recording video.
Actually it was Nokia wired headset, and Z5 used it to record mono audio without any questions
I ran the service test suggested above:
*#*#7378423#*#*
And the recorded sound was very very faint. How do I increase the mic's input level on a z5 compact with nougat 7.1.1?
Ian
