Notification bar issues
Passadena
Spot bar
Hello,
I can not scroll down the taskbar to display notifications.
What to do?
Thank you
Bonjour,
Je ne peux plus dérouler la barre de tâche pour afficher les notifications .
Que faire?
Merci
Uliwooly
@Passadena
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
If your phone doesn't have a film or glass protector, perform this
settings > about phone > diagnostics > test > test touchscreen > if you encounter an issue/error > contact your Local support to get it repaired.
