Notifications issues
bostjanv
Hello,
I started using the Xperia Z1 Compact just recently, and I have the following question: on my previous phone the call or message notification worked in such a way that if I did not respond the first time, the notification would be repeated periodically. I couldn't figure out how to set up such behavior on the Xperia Z1 Compact (periodic repeats). Can someone help me, please.
Regards,
bostjanv
JiYong
Most people will use the notification light in the top speaker for that.
But you will need to keep an eye on your phone.
If you want to keep your phone in your pocket, you can try an app.
This was the first one I found: https://play.google.com/store/apps/details?id=org.intoorbit.renotify&hl=en
Samuel1
Hero
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I'm not really sure what you mean. Could you please elaborate and describe the function you want a bit further?
JiYong
bostjanv
That's exactly what I need. Thanks. bostjanv
