Original or Fake Display Spare Part?
Because of my broken Display Glass, i want to fix it by myself.
But I´m confused if all the Spare Parts on Ebay or Amazon are Original or not.
How can I check if it s Original or not?
heintz
Uliwooly
If you dont get it replaced by your local Xperia care chances are that they might not be original
Uliwooly
saubhikdatta
My Purchase Location and Stay Locations are different,
So donot have an option to get the handset repaired at Xperia Care,
So wondering whether the Spare parts from Ebay are Original.
I even asked the seller before purchasing, the seller says its Original:
Dear saubhik_datta2003,
yes it's original product
- velocity_tech_supply_us
Click the Respond button to reply through Messages, or go to your email to reply
Respond
To: velocity_tech_supply_us
Subject: Details about item: saubhik_datta2003 sent a message about Back Rear Camera Flex for Sony Xperia Z3 Compact D58030 D5833 #131497639290
Sent Date: 06-Sep-2015 22:09:13 IST
Dear velocity_tech_supply_us,
Is this camera from OEM Sony original?
- saubhik_datta2003
Item ID:131497639290
End time:24-Sep-2015 16:07:23 IST
Seller:
velocity_tech_supply_us (30086)
98.4% Positive Feedback
Member since 24-Mar-2010 in Hong Kong
Listing Status:This message was sent while the listing was active.
K-Linerz
If you're in that UK or Europe, it will be worth using this company. All parts are official Sony
