Is there any way to get back the old baked-in photo editor? The new version is very dumbed down. I miss the curves option in particular. Really regret "upgrading"
Solved! Go to Solution.
You could check the XDA forum or use a third party app such as Pixlr
I prefer pixlr but you could contact your local Xperia care
Yes, the new editor is a **bleep** and the local support says that there is not any way to get back to the previous version. Bad Sony.. =(
