Photos (specific) on phone but not in any folder. Xperia Z5
Lloydo
There are some important (personal) photos that i am unable to take off the phone.
They are not on the SD card.
If i take a new photo, i can recieve them and take them off via USB, find the folder and move them like normal.
The Issue is:
For a specific time or section my photos are not able to be taken off the phone.
I can viem them like normal via the Albums App and others but beyond that i cannot find them.
Despite going through every single folder on the memory and SD, they are not visible.
There are a few hundred important photos, and while i could email a few at a time to myself this would take way too long.
Though i cannot find the Photos through folders, the photo detailed file name is for example:
Saved to: Internal memory
File Path: /storage/emulated/0/DCIM/100ANDRO/DSC_0001.JPG
Kind Regards
pravi
Install quick pic from playstore!  It can move pics from folder to folder in galley itself
The Issue is:
Kind Regards
GhKerh
Hello!
For that I use X-plore. Install this app, it's very easy Slightly_smiling_Face
