Hello, am I just a BFU or it is not possible to make contacts display in normal natural surname firstname format?... I somehow managed to make it be sorted by surname, but it is total mess because surname is displayed as second which does not make any sense to me...
Solved! Go to Solution.
Hi @McVitas,
The setting you're looking for is called "View contacts as". Follow alexdon's instructions and you should find it in the Filter menu.
LOL I would really not look for this settings in "filter" Thanks
You're welcome, and happy holidays!
