balajixp
Re Update
Hi All,
            I have xperia zr mobile, and the android version is 4.1.2, with base band .310, every time I checked through pc companion its saying that the software is up date, but I know there is an update available,  how to update any idea and also every time when I connect to pc a pop is asking to install pc cpompanion how to disable it. Thanks in advance for helping.
Uliwooly
Settings > Xperia > USB connectivity
19 REPLIES 19
Uliwooly
balajixp
Hi thanks for ur reply but wat abt the update? any idea
Uliwooly
You have 2 options
1) wait for the update to be approved and released in your country
or
2) manually update the phone
balajixp
Ok I will wait may be i will get the notification when 4.3 is released. I have another problem. In my update center its showing updates available for two apps, when i try to update its starting and its says pending network, both on wifi and mobile data its the same any I dea for the above problem?
Uliwooly
That's quite odd, restart the phone and try again
balajixp
I have restarted it many times but its saying the same again and agian, pls help me with this, its so annoying for me
Uliwooly
repair your phone with SUS or PCC
Update Service (SUS)
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
balajixp
Sorry I forgot to tell u this, I have already repaired my phone using PCC, in order to get the latest available software expecting it to be 4.2.2, But I got this .310 instead of it, I have the above problem only after I repaired my phone.
balajixp
Oh Come n guys help me, and also whether there is any indication available in the phone if its accessing 3g signal
