Re: Z3 Dual question
Aliibra
Hi I purchased the xperia z3 two days ago, as I used it as normal the screen stopped working and dont give a picture, but I'm getting calls and messages and I have not used it underwater and the phone is not subjected to any strike at all. any ideas ?
Aliibra
@uliwooly Thank you for your help, but i tried to download a new softwar ,i doesn't work now i will change the screen and i think it will work.
(New problem: cannot find a white screen ! )
Uliwooly
@Aliibra
Try this:
1. restart your phone
2. if you have a protective case and/or film, remove them and check again
Uliwooly
If 1 and 2 doesn't work then repair it with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Aliibra
