SensMe slideshow keeps showing up even though I selected other daydream app
gardebring
I have setup my Xperia Z1 to start "Clock plus" when I put it in the docking station.
This I have done via Display > Daydreams > Clock plus
Now, even though "SensMe slideshow" is no longer selected it randomly starts when I put the devide in the dock anyway.
Sometimes I get SensMe, sometimes I get Clock plus.
100% of the times I will get into the SensMe UI then I undock the device.
Seems to be a bug since I have deselected SenseMe UI in the daydreams settings.
Alexander1
Champion
First of all I suggest that you check Smart Connect to see if it is set to start SensMe slideshow when phone connects to the dock.
4 REPLIES 4
Alexander1
Champion
gardebring
That was it! Thanks Slightly_smiling_Face
awsmgannnaway
where might I find smart connect so that I can turn off the sensme slideshow
thank you.
profile.country.RO.title
_alexdon_
Smart connect should be in the app menu.
alexdon
