Hello,
Right now the camera app on my Z3 compact is the only app saving on my SD card. When I download files or the stuff from whatsapp, everything is saved on the phone. With my last mobil I could choose the default to be either the phone or the card. Is there anything like that on the Z3 compact? The first time I used the cam after I put in the SD card the app asked if I wanted to save on the card from now on. I would like that for the other apps aswell.
Thank you
Solved! Go to Solution.
If the app supports direct downloading to SD,then it works.
So all I am looking to do is to save pictures that I download from the internet and phone screen shots to my Micro SD as default. I am not too concerned about apps.
Is that possible? I am thinking the answer is no, but if I can, can someone please tell me how.
Thanks.
Is this a joke? Why would a smartphone company even not consider this simple idea to allow an android owner to do as he pleases in saving where he wants and where he wants to sace it. It's like everybody bought an external sd card to not even use it! I hope someday in maybe 20 years, that android or the corporative cellphones companies will creat something that it can allow us to have that option.
This is a ridiculous answer. If this is how the phone is set up then it needs to be changed. There's no reason why I have a 64g SD card but have to sit there and manually transfer files onto it. Downloads to music and photos should go directly onto the external memory and the option to choose between should be available.
it sony, I love your phones but the functionalities are really annoying sometimes.
Hi
This seems a pretty basic requirement that other phone manufacturers are able to offer (e.g. Nokia/Microsoft, HTC etc.) so it is somewhat deficient to simply state that this is not available.
I've also found that regardless of whether I move an app (which is a very timeconsuming task let's face it) every time it then updates, it moves back to the internal storage disc.
I am now getting "system disc full" warnings. So, despite having moved all apps to the SD card, they're now back on the internal storage.
Please tell me this is being looked at and a solution is due soon?!!
Thank you.
