simlock counter
don12
simlock counter
how possible is it to reset counter for blocked simlock counter
profile.country.RO.title
_alexdon_
@Bezza Contact your Local support as it seems they should be able to help.
alexdon
Thommo
Genius
You can't - Once it's on 0 (Zero) and the title has a [x] symbol then it's now hard locked
Bezza
Hi its possible do something with hard locked z1 compact ? thanks
_alexdon_
alexdon
