I recently performed a reset to factory settings and now I'm missing my Sony Tasks app.
I expected it to automatically reinstall through the Update Center, but apparently not.
Can't find back the Sony Tasks app in google play store.
Any ideas how to solve this?
The tasks I've backed up can't be restored at the moment as I no longer have app.
Solved! Go to Solution.
Thanks!
No problem.
Hello,
I have the same problem with the missing task app.
I tried to install with the update given by dropbox above but my phone does not install the app again.
What can i do?
I forget where I saw it on this forum, but the Tasks feature has been baked into the Sony Calendar app. If you open that and pull out the side menu, you'll see Tasks as an option.
