Sony Xperia Z does not detect AT & T SIM card in USA. Worked fine in INDIA for 4 months
Cinni
Hello,
I have used my Sony Xperia Z in India for 4 months. It worked fine for indian mobile services providers.
Recently, I have moved to USA, and found - my phone does not detect AT & T sim card here.
The same sim card works fine on other phone. But not with my Sony Xperia Z
Please guide me what could be the issue.
Thanks alot
Cinni
Cinni
Just had a talk with Sony Xperia support team and came to know - xperia z bought from indian market will not work in us market as frequency differes and US mobile service providers do not support indian frequency.
My Xperia Z - model c6602 is of no use in US. Its for Indian market only
9 REPLIES 9
Uliwooly
Which version do you have the C6602 or C6603?
btw this subforum is for the Xperia Z1 not the Xperia Z
Don't forget to give Kudos
Uliwooly
For the Xperia Z to work with the big blue
3G
850 / 900 / 2100 - C6603
850 / 900 / 1700 / 1900 / 2100 - C6602
4G Network LTE 800 / 850 / 900 / 1800 / 2100 / 2600 - C6603
USA Carrier Voice Frequencies 3G 4G 3G Technology 4G Technology
AT&T850 MHz, 1900 MHz850 MHz, 1900 MHz700 MHz, 1700/2100 MHzGSM/HSPA+LTE
MetroPCS1700/2100 MHz, 1900 MHz1700/2100 MHz, 1900 MHz1700/2100 MHzCDMA/EVDOLTE
Sprint800 MHz, 1900 MHz1900 MHz800 MHz, 1900 MHz, 2500 MHzCDMA/EVDOWiMAX (2010–present)
LTE (2012–present)
T-Mobile USA1700/2100 MHz, 1900 MHz1700/2100 MHz, 1900 MHz1700/2100 MHzGSM/HSPA+LTE (2013)
Verizon850 MHz, 1900 MHz850 MHz, 1900 MHz700 MHz, 1700/2100 MHz (Planned)CDMA/EVDOLTE [3][4]
U.S. Cellular800 MHz, 1900 MHz
Uliwooly
Do you have the correct APN settings
settings > more > mobile networks > access point names > menu > add New
Name pta
MMSC: http://mmsc.mobile.att.net
MMS proxy: 80
MCC: 310
MNC: 410
Authentication type: None
APN type: Not set
Bearer: unspecified
Menu > save > restart your phone
Cinni
I did same!
Saved new APN as suggested above, restarted phone. But no luck!
Cinni
I supppose the one i have supports C6602, C6603 and 4G LTE
The AT & T sim card i have runs on on 4G LTE.
Still not getting connected to network.
2G NetworkGSM 850 / 900 / 1800 / 1900 - C6602, C6603
3G NetworkHSDPA 850 / 900 / 2100 - C6603
 HSDPA 850 / 900 / 1700 / 1900 / 2100 - C6602
4G NetworkLTE 800 / 850 / 900 / 1800 / 2100 / 2600 - C6603
SIMMicro-SIM
Announced2013, January
StatusAvailable. Released 2013, February
Cinni
Uliwooly
That doesn't seem right, AT&T use 850 and 1900 for 3G, in some areas both in some others only one or the other, and the C6602 support them, umm quite odd. I have the C6603 but I've seen other users with the C6602 here in the US, use the search bar and find those threads.
Cinni
Hey, i got my Sony Xperia Z working in US with AT & T sim card.
There was a mistaken in inserting SIM card in the slot. My bad.
Thanks everyone though for your input!
Rohitsairaj
This plan didnt work for my sony xperia c2305
