Sony Xperia Z1, Music Unlimited and Throw
Harime
Hello,
I have a Sony Xperia Z1, a Sony Bravia KDL-40EX721 and a Sony Bluray BDV-N590.
While using the Walkman app with Music Unlimited, i'm trying to use Throw to DLNA the music to my TV or Bluray and it's not working. It says something like "Error could not show media contents".
If the Throw option is available in the Walkman app with Music Unlimited, why is it not working? Do i have to configure anything?
Throw works with the contents stored on my phone (images, music and videos) but it doesn't with the Music Unlimited audio.
Is there a fix for this?
Thanks.
Rickard
Master
I got more information and unfortunately you can't use Throw over DLNA for Music Unlimited.
10 REPLIES 10
Rictv_me
Go onto Sony Entertainment Network and ensure the Music Unlimited is activated and registered for your TV etc
This activation can be found under 'Manage Premium Services'
You will get an activation code for your Bravia TV - type this in at the prompt and and it should all work .
The same goes for Movies Unlimited (plus Netflix / LoveFilm etc)
Harime
My Bravia is registered with Music Unlimited, as well as my Bluray Player.
Still i get the "Error could not show media contents".
It works with the TV app, the Bluray app, but i can't "Throw" from the phone.
I'm wondering what's the point of having that option if it doesn't work.
Rickard
Master
Not sure if this is supposed to work with DLNA (Throw is also used for bluetooth) but please send me a PM with a relevant topic and the following information and i'll forward this:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
Harime
Hello Rickard,
PM sent.
Let me know if you need more info.
Thank you for your support.
Rickard
Master
Harime
It's a pity, because without the DLNA i really don't see any added value over Spotify and will probably stick to my subscription with them.
Thank you anyway for your great support and interest in solving my question.
dr4ke
I have my Z1 hooked up to my car (ford s-max) but for some reason why I try to throw music from the Walkman app (where I have Sony unlimited) it fails and says it wasn't possible.
I can't figure out why?? Can anyone help?
dr4ke
