Sony xperia z3 compact docomo
Renesoterol
How to solve this problem? My phone very poor signal and the signal bars they have letter R at the top
Rhydz
The 'R' suggests that you are roaming.
As for the reason for poor signal, there are too many things that could affect signal strength to diagnose remotely.  My first step would be to try to find ehere the local mast is located.  Also check that you have the correct netwok provider selected on the phone.
