Hi, I have an issue with notifications on my z3. Every notification works except with messages. When i receive a message i have no notification. Have checked settings and they are all fine. Regards Steve Johnson
Solved! Go to Solution.
Ok, try this: settings-apps-all, tap on 3 dots and reset app preferences. This will reset some of your apps set up to open certain files or links but you can set them up again.
Messages from default app or those that require an internet connection?
I have checked and double checked all settings. Deleted loads of Apps,but not all. I get notifications for everything elsebut not messages!!!!!!!
Just text messages.
Safe mode is different, it will only load default apps so you can check if there is an app acting up and creating the problem you experience.
Press power button, a menu will pop up. Press longer on turn off and reboot in safe mode should come up.
